Skip to main content
Your basket
Monthly payment
  • every month for months, then
  • months contract
  • no annual contract
Monthly payment total
£xx
One-off payment
One-off payment total
£xx
Included with your package
Summary
Monthly payment
    One-off payments
    Reward Card included
    to say thanks for signing up
    Amazon gift card
    cashback icon
    Today's payment
    Today's payment
    Understanding your IP address
    All you need to know about IP addresses and how you should use them.
    IP address FAQs
    Check our handy guide to find out what is an IP address and all you need to know about it.
    Whenever you go online, your router or modem is given an IP address. Your IP is like your phone number, unique to you and used as a way to identify and reach you.
    Your IP address will either be dynamic or static. Dynamic means you're given a different IP each time you connect to the Internet. Whereas static means you'll be given the same one each time.
    All our current broadband products are given a dynamic IP but you'll have the option of changing to a static one. If you're using an older product check below for more about your IP. If you're not sure what you've got, check Connection Settings, under Manage Account in My Account, or see the question below.
    It depends on the broadband package you've got.
    Current packages
    Account type Default IP type Switch between static and dynamic? Multiple IPs (IP blocks) available?
    Home products Dynamic Yes - £5 setup charge No
    Business products Dynamic Yes – no extra charge Yes
    SDSL Dynamic Yes – no extra charge Yes
    Old packages
    Plusnet Essentials / Essentials Fibre Dynamic No No
    Plusnet Unlimited Fibre Dynamic Yes - £5 setup charge No
    Plusnet Value Dynamic No No
    Plusnet Extra Dynamic Yes - £5 setup charge No
    Plusnet Pro Dynamic Yes - £5 setup charge No
    Plusnet Premium Dynamic Yes - £5 setup charge No
    Unlimited Dynamic Yes - £5 setup charge No
    Plusnet Essential Dynamic Yes - £5 setup charge No
    Broadband Your Way (all options) Dynamic Yes - £5 setup charge No
    Broadband Plus Dynamic No No
    Broadband Premier (all Options) Static No No
    Broadband PAYG, Home Lite Static No No
    Business Options 1-3 Dynamic Yes – no extra charge Yes
    Business Static No Yes
    Small Business Static No Yes
    Teleworker Static No Yes
    Homeworker Static No Yes
    1. Log in to My Account
    2. Click on Add-Ons
    3. You'll be able to see what your IP settings are at the moment. Switch between static and dynamic by selecting the option you want to use. It usually costs £5 to do that. It's not always possible for some of our older broadband packages, but you can check whether or not you're eligible
    2. Go to Connection Settings
    3. Click on Static IP
    4. To switch from a dynamic IP to a static IP, click Activate your Static IP. If you already have a static IP and would like to switch to dynamic just call our Business Support Team on 0800 028 0282
    • There's a £5 setup fee to start using a static IP if you've got home broadband and your package allows you to switch IPs
    • You'll need to reboot your router before you'll see any change
    • If you remove a static IP, you probably won't get the same address if you switch back again
    • The option to choose a static IP won't show up for accounts that aren't able to switch between the two
    You'll need to change to a broadband package that allows you to switch IPs. To do that, just go to Offers and Upgrades and choose a package that has a static IP.
    You can get an IP block if you've got business broadband. It's when you need a range of IPs (either four or eight), so you can assign different ones to different devices. It's handy if you've got several different devices or services each requiring a public-facing IP address, like a firewall on one and an SSL website on another, because you won't be able to use things like port forwarding or Network Address Translation (also commonly called NAT addressing).
    To get a 4-block IP:
    1. Go to the Help Assistant and select IP Addresses
    2. In the text box, let us know why you need a 4-block IP and why you can't use port forwarding with your set-up (this'll help us understand what you need us to do)
    3. Click Send your question to the support team and we'll be in touch
    To get an 8-block IP:
    2. In the text box, let us know why you need an 8-block IP
    If you need help with any of that, just let us know.
    Was this article helpful?
    More ways to get help
    Plusnet community
    Talk to our community
    Contact our team
    Or call 0330 1239 123
    Sign Language service
    Contact us using British Sign Language
    My Account
    Sign into Broadband
